Remove the 9 screws from the back cover with the Phillips #0 screwdriver. NOTE* You do not need to remove the screws completely as you just need to loosen them enough to remove the cover.
Once all 9 screws have been loosened, you can start to pry apart the back cover with your metal or plastic blade. I like to start from the top right hinge area. (See pic)
Remove the 3 battery screws with a Phillips #0 screwdriver.
Temporarily disconnect the sticker on the bottom left corner of the battery. You will need to reconnect this sticker when installing the new battery.
Lift the battery out of the palm rest. You may feel some resistance while trying to remove the battery. There is a piece of double-sided tape underneath the battery in the top left corner. (See video)
Disconnect the motherboard battery cable from the top of the battery.
