Dell Chromebook 3100 2-in-1 Motherboard Replacement
  1. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove adhesive tape that secures the speaker cable.
    • Disconnect the speaker cable from the connector on the system board.
  7. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker cable from the retention clips.
  8. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the speakers from the device.
  9. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the keyboard cable.
  10. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two input-output board cables from the motherboard.
  11. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the touchpad cable.
    • Disconnect the USB Type-C power cable.
  12. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single 3 mm screw that secures the WLAN bracket to the system board using a Phillips #1 screwdriver.
    • Lift the WLAN bracket from the system board.
    • After lifting the bracket, carefully unplug the two coaxial cables.
  13. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 4 mm screw that secures the eDP bracket to the motherboard using a Phillips #1 screwdriver.
    • Remove the eDP bracket.
  14. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the display cable from the motherboard by using a plastic opening pick.
  15. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 4 mm screws that secure the motherboard using a Phillips #1 screwdriver.
  16. Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 3100 2-in-1 Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the motherboard from the computer.
Muhammad Ali
crwdns2935283:009/02/21crwdne2935283:0
352 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-1, Pee Fall 2021 crwdns2935289:0Gateway, Team 1-1, Pee Fall 2021crwdne2935289:0
GCC-PEE-F21S1G1
Any idea how to use the USB repair shim? Dell's guide didn't help
Josie - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 2,467
