Unscrew the nine PH#0 captive screws on the bottom of the device.
Use a pick to run along the outside of the device popping all the clips. Prying should not be necessary.
Disconnect the daughterboard data cables.
Pull the daughterboard power cable out of its socket parallel to the motherboard.
Remove the M2x3 screw and cover, and disconnect the antenna cables.
Disconnect the touchpad, keyboard, and speakers where shown.
Remove the four M2x4 screws, as well as the cover over the LVDS cable (top right).
Lift the motherboard out from the left side and pull away from the body of the chromebook.
Apply lateral force to the IO shield to break the adhesive holding it to the motherboard.
During reassembly, make sure to include a thermal pad on the CPU. Usually you can reuse the one from the previous motherboard, but it's best to have access to a new pad in case the old one is not usable.
