Unscrew the nine PH#0 captive screws on the bottom of the device.
Use a pick to run along the outside of the device popping all the clips. Prying should not be necessary.
Disconnect the keyboard ribbon cable and pull it free. Make sure to undo the latch all the way; you shouldn't have to put hardly any force into pulling the cable out.
Open the computer to a 90º angle for the next step.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Locate the two screw posts connected to the keyboard, and give them a hard "push" with your blunt tweezers, spudger, screwdriver, or anything else vaguely stick-shaped.
Remove the keyboard, freeing any clips that didn't come detached in the last step.
