Having trouble with broken or stick keys on your keyboard? This guide will provide you simple step-by-step instructions on replacing your keyboard for the Chromebook 13-7310.
Remove the eleven 3mm Phillips #1 screws.
Use a plastic opening tool to gently remove the back panel.
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
Remove the four 2mm screws on the sides of the battery.
To remove the battery, lift up on one side to get your fingers underneath and lift away.
Gently pull to unplug fan connector.
Remove the eight 2mm screws securing the motherboard in place.
Release cable for the LED charging indicator by pulling up on connector.
Pull up on connector tab to release IO board cable.
Pull up on connector tab to release touchpad cable.
Release the keyboard backlight cable.
Gently lift up the motherboard to remove it.
Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using your fingernails, pull the cooling fan cables loose from the motherboard.
Finally, lift the fan assembly away from the computer.
Remove the single 2mm screw securing the IO board to the laptop.
Pull up on the connector to release the IO board cable from the motherboard.
Gently lift up the keyboard and remove.
I’ve never pulled apart a computer before, and this guide was perfect! thanks
