Dell Chromebook 11 CB1C13 Fan Replacement
  1. Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Fan Replacement, Fan: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two wires that connect the fan to the device. One black, and one white.
    • Move these wires off of the fan by gently pulling on them.
    • Locate the two 8mm Philips #0 screws that connect the fan to the device.
    • Remove these screws using a Philips #0 screwdriver.
  3. Dell Chromebook 11 CB1C13 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 11 CB1C13 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 11 CB1C13 Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool.
    • The pin port can be very delicate. Any major bending or twisting can cause permanent damage to the port, and may leave it unable to work.
Bryan Allen
crwdns2935283:010/20/17crwdne2935283:0
272 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 crwdns2935289:0UMass Dartmouth, Team S3-G6, Bailey Fall 2017crwdne2935289:0
UMASSD-BAILEY-F17S3G6
Ram?
Can i change the ram?
flip - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,183
