Dell Chromebook 11 CB1C13 DC Jack Cable Replacement
    • Get your trusty Phillips screwdriver and unscrew the Phillips Screws and put them somewhere safe.
    • Then pry open and remove bottom case cover.
    • Now what you want to do is find two screws protecting the battery. Unscrew them and put them somewhere safe.
    • Remove the cable from the battery and put it somewhere safe.
    • Now, find the DC Jack Cable. It should be in the top right corner.
    • To remove the DC Jack Cable, use your fingernails and try to remove it. Once out, put it somewhere safe.
    • To put in a new one, insert it with a lot of pressure and it should be secure.
To reassemble your device, follow steps 1 and 2 in reverse order.
EmreTech
crwdns2935283:005/12/18crwdne2935283:0
199 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 166
