Dell Alienware M17x R2 Memory Modules Replacement
  1. Dell Alienware M17x R2 Memory Modules Replacement, Loosen the Screw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Loosen the captive screw that secures the memory-module door to the computer base.
  2. Dell Alienware M17x R2 Memory Modules Replacement, Sliding the Memory Module Door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the memory-module door to release the tabs and lift the memory- module door out of the computer base.
  3. Dell Alienware M17x R2 Memory Modules Replacement, Popping up the Memory Module: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware M17x R2 Memory Modules Replacement, Popping up the Memory Module: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware M17x R2 Memory Modules Replacement, Popping up the Memory Module: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
    • Use your fingertips to carefully spread apart the spring-locks on the memory module connector until the module pops up.
  4. Dell Alienware M17x R2 Memory Modules Replacement, Removing the Memory Module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the memory module.
  5. Dell Alienware M17x R2 Memory Modules Replacement, Align the Notch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware M17x R2 Memory Modules Replacement, Align the Notch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • CAUTION: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch on the NEW memory module with the tab on the memory module connector.
  6. Dell Alienware M17x R2 Memory Modules Replacement, Inserting the Memory Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware M17x R2 Memory Modules Replacement, Inserting the Memory Module: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the module into the memory module connector at a 45-degree angle, and press the module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
    • CAUTION: If the memory module door is difficult to close, remove the memory module and reinstall it. Forcing the memory module door to close may damage your computer.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79 675 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01 991crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 759
