In this guide, we will be showing you how to remove and replace the Battery.
Disconnect the battery cable from the system board.
Remove the screws that secure the battery to the computer base.
Using the battery cable, lift and release the battery from the tabs on the computer base.
Turn the computer over and open the display.
Press and hold the power button for five seconds to ground the system board.
Slide the NEW battery under the tabs on the computer base.
Align the screw holes on the battery with the screw holes on the computer base.
Replace the screws that secure the battery to the computer base.
Connect the battery cable to the system board.
