Dell Alienware 15 R3 Battery Replacement
  1. Dell Alienware 15 R3 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
    The Wlan cable holds the base to the computer along with a little wire in the back left corner.
    darkdestroyer66 - crwdns2934203:0crwdne2934203:0
    Mine has 12 screws not 9. one card also to remove, (held by screw), and 2 sets of connectors
    Sean - crwdns2934203:0crwdne2934203:0
    Plus you need to put the splonger in the edge below the usb connections, not on the area highlighted in the picture above. Yeah there are way more screws than 9. You also need to remove the screws out of any m.2 ssd drives, msata drives, and wlan card. You also need to unplug each ribbon cable, and unplug and unwire the tronlights on both sides of the laptop.
    This youtube video is really helpful for this part: https://youtu.be/QxJznOkvyic?si=eDLzrheu...
    jason -
  6. Dell Alienware 15 R3 Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
  7. Dell Alienware 15 R3 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
    • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
    While I did finish my battery replacement using this guide, I had to remove around 15 screws to release the midframe, not the nine listed. This is likely due to the source machine being a different h/w version than mine. It still didn't take long and wasn't much more difficult. I swapped a 68Wh dead battery with a 99Wh version. Now it lasts around 7 hours on a charge. Much better :D
    Tyler Regas - crwdns2934203:0crwdne2934203:0
Jake Nelson
crwdns2935283:009/22/22crwdne2935283:0
623 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 4-1, Saru Jimmy Fall 2022 crwdns2935289:0University of North Texas, Team 4-1, Saru Jimmy Fall 2022crwdne2935289:0
UNT-SARU JIMMY-F22S4G1
does not seem to be for my alienware r3 15 inch
Craig Anderson - crwdns2934203:0crwdne2934203:0
step 5 - you need to unscrew 10 screws, not 9. You missed the one in the center.
Mike Kravchenko - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 196
crwdns2942667:0crwdne2942667:0 7,703
