Dell Alienware 15 R3 Battery Replacement
    1. Dell Alienware 15 R3 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Before you begin, turn off the laptop and unplug the charger.
      • Flip the laptop over so that the backside is facing up.
      • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
      • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
    2. Dell Alienware 15 R3 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the opening tool to pry the back case from the computer.
      • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
      • Start from the black vent for an easier removal.
      • Lift the back case off of the laptop.
    1. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
    2. Dell Alienware 15 R3 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
    3. Dell Alienware 15 R3 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
      • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
    1. Dell Alienware 15 R3 Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
    2. Dell Alienware 15 R3 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 15 R3 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
      • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
Jake Nelson
crwdns2935283:009/22/22crwdne2935283:0
642 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 4-1, Saru Jimmy Fall 2022 crwdns2935289:0University of North Texas, Team 4-1, Saru Jimmy Fall 2022crwdne2935289:0
UNT-SARU JIMMY-F22S4G1
crwdns2935297:084crwdne2935297:0
does not seem to be for my alienware r3 15 inch
Craig Anderson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
step 5 - you need to unscrew 10 screws, not 9. You missed the one in the center.
Mike Kravchenko - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 56
crwdns2936753:030crwdne2936753:0 232
crwdns2942667:0crwdne2942667:0 10,937
