Dell Alienware 14 Wireless Mini-Card Replacement
  1. Dell Alienware 14 Wireless Mini-Card Replacement, Close the Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Wireless Mini-Card Replacement, Slide and Lift the Base Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Tabs: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Wireless Mini-Card Replacement, Replace the Screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Wireless Mini-Card Replacement, Turn the Computer Over: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Wireless Mini-Card Replacement, Disconnecting the Battery Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  8. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Wireless Mini-Card Replacement, Using the Battery Cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Wireless Mini-Card Replacement, Turn the Computer Over: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Wireless Mini-Card Replacement, The Power Button: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Tabs: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Screw Holes: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Wireless Mini-Card Replacement, Replace the Screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Wireless Mini-Card Replacement, Connect the Battery Cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Wireless Mini-Card Replacement, Disconnect the Antenna Cables: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 14 Wireless Mini-Card Replacement, Disconnect the Antenna Cables: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  17. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screw: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw that secures the wireless mini-card to the system board.
  18. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Wireless-Mini Card: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Wireless-Mini Card: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide and remove the wireless-mini card from the system-board connector.
  19. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Notch: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the notch on the NEW wireless mini-card with the tab on the system-board connector.
    • CAUTION: Use firm and even pressure to slide the wireless mini-card into place. If you use excessive force, you may damage the connector.
    • CAUTION: The connectors are keyed to ensure correct insertion. If you feel resistance, check the connectors on the wireless mini-card and on the system-board connector, and realign the wireless mini-card.
    • CAUTION: To avoid damage to the wireless mini-card, never place cables under the wireless mini-card.
  20. Dell Alienware 14 Wireless Mini-Card Replacement, Inserting the Wireless Mini-Card: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the wireless mini-card at a 45-degree angle into the system-board connector.
  21. Dell Alienware 14 Wireless Mini-Card Replacement, Securing the Wireless Mini-Card: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the other end of the wireless mini-card down into the slot on the system board and replace the screw that secures the wireless mini-card to the system board.
  22. Dell Alienware 14 Wireless Mini-Card Replacement, Connect the Antenna Cables: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the antenna cables to the connectors on the wireless mini-card.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79,675 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 239
