Dell Alienware 14 Memory Module Replacement
  1. Dell Alienware 14 Memory Module Replacement, Close the Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Memory Module Replacement, Remove the Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 14 Memory Module Replacement, Remove the Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Memory Module Replacement, Slide and Lift the Base Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Memory Module Replacement, Align the Tabs: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Memory Module Replacement, Replace the Screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Memory Module Replacement, Turn the Computer Over: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Memory Module Replacement, Disconnecting the Battery Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  8. Dell Alienware 14 Memory Module Replacement, Remove the Screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Memory Module Replacement, Using the Battery Cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Memory Module Replacement, Turn the Computer Over: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Memory Module Replacement, The Power Button: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Memory Module Replacement, Align the Tabs: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Memory Module Replacement, Align the Screw Holes: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Memory Module Replacement, Replace the Screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Memory Module Replacement, Connect the Battery Cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  17. Dell Alienware 14 Memory Module Replacement, Remove the Memory Module: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 14 Memory Module Replacement, Remove the Memory Module: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the memory module from the memory-module connector.
  18. Dell Alienware 14 Memory Module Replacement, Align the Notch: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 14 Memory Module Replacement, Align the Notch: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  19. Dell Alienware 14 Memory Module Replacement, Slide the Memory Module: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79,675 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 282
