Dell Alienware 13 Speakers Replacement
  1. Dell Alienware 13 Speakers Replacement, Base Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Heavy-Duty Spudger
  4. Dell Alienware 13 Speakers Replacement, Computer Base: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 13 Speakers Replacement, Computer Base: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery cable from the battery cable terminal.
  5. Dell Alienware 13 Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove (4) 6 mm Phillips head screws from the solid-state metal drive bracket, using a Phillips # 1 screwdriver.
  6. Dell Alienware 13 Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the pull tab to pivot the solid-state drive bracket upwards. Remove the bracket from the computer base.
  7. Dell Alienware 13 Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the pull tab, disconnect the black solid-state drive cable from the system board.
  8. Dell Alienware 13 Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove (2) 3 mm Phillips head screws, using a Phillips # 0 screwdriver, that connect the solid-state drive assembly to the computer base.
  9. Dell Alienware 13 Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up on the solid-state drive assembly to remove it from the computer base.
  10. Dell Alienware 13 Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate two cables labeled, "KB Backlight" (orange) and "KB Membrane" (black). Lift up on the latches to disconnect the cables from the system board.
    • The latches that connect the cables to the system board are very delicate. Handle with care to avoid damaging them.
  11. Dell Alienware 13 Speakers Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove (8) 9 mm Phillips head screws using a Phillips # 1 screwdriver, that secures the palm-rest assembly to the computer base.
    • Remove (4) 8 mm Phillips head screws using a Phillips # 1 screwdriver.
    • Remove (2) 7 mm Phillips head screws using a Phillips # 1 screwdriver.
  12. Dell Alienware 13 Speakers Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the computer base slightly towards you and push the release tabs on the palm-rest assembly until it pops out using a spudger.
  13. Dell Alienware 13 Speakers Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the computer over and open the display as far as possible.
    • Using a plastic spudger, pry up along the edges of the palm-rest assembly.
    • Gently lift the palm-rest assembly.
  14. Dell Alienware 13 Speakers Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the connector latch and disconnect the power-button board cable from the system board. Identified as a cable with a blue tab.
    • Lift the palm-rest assembly off the computer base.
  15. Dell Alienware 13 Speakers Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the display as far as possible.
    • Remove (2) 3 mm Phillips head screws, using a Phillips head #0 screwdriver, that secure the hinge caps to the display hinges.
    • Slide and lift the hinge caps off the display hinges.
  16. Dell Alienware 13 Speakers Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the display and turn the computer over.
    • Remove (1) 2 mm Phillips head screw, using a Phillips head # 0 screwdriver, that secures the wireless-card bracket to the wireless card.
  17. Dell Alienware 13 Speakers Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Heavy-Duty Spudger
    • Disconnect the antenna cables from the wireless card using a heavy duty spudger. The wires can be removed by applying a force directed upward, away from the device.
  18. Dell Alienware 13 Speakers Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the computer over and open the display.
    • Peel off the adhesive tapes that secure the antenna cables to the system board.
    • Make note of how the cables are routed before removing any cables from their routing guide.
  19. Dell Alienware 13 Speakers Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the connector latch and disconnect the display cable from the system board.
    • Disconnect the logo-board cable from the system board.
    • Remove the antenna cables, display cable, and logo-board cable from the routing guides on the display hinges.
  20. Dell Alienware 13 Speakers Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove (4) 8 mm Phillips head screws, using a Phillips # 1 screwdriver, that secure the display assembly to the computer base.
    • Lift the display assembly off the computer base.
  21. Dell Alienware 13 Speakers Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the (2) 6 mm Phillips head screws securing the power adapter port bracket with a #1 Phillips screwdriver.
    • Lift and remove the power adapter port bracket.
  22. Dell Alienware 13 Speakers Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and remove the power adapter port from the computer base.
  23. Dell Alienware 13 Speakers Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the speaker cable connector from the service board.
  24. Dell Alienware 13 Speakers Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove (3) 6 mm Phillips head screws securing the service board with a #1 Phillips screwdriver.
    • Lift up on the service board assembly using a heavy duty spudger and slide the board towards the battery to remove from the base.
  25. Dell Alienware 13 Speakers Replacement, Battery: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker cable from the cable clip on the battery.
  26. Dell Alienware 13 Speakers Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove (2) 6 mm Phillips head screws securing the battery to the computer base with a #1 Phillips screwdriver.
    • Lift up and remove the battery from the computer base.
    • Lithium can be explosive, especially when wet. Be careful when handling and disposing of lithium-ion batteries.
  27. Dell Alienware 13 Speakers Replacement, Speakers: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement, Speakers: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Alienware 13 Speakers Replacement, Speakers: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the battery, lift up on the speakers and wires to fully removed from the base panel.
Adam Russell
crwdns2935283:009/26/16crwdne2935283:0
898 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-2, Eyestone Fall 2016 crwdns2935289:0USF Tampa, Team 14-2, Eyestone Fall 2016crwdne2935289:0
USFT-EYESTONE-F16S14G2
crwdns2942667:0crwdne2942667:0 547
