In this guide, we will be showing you how to remove and replace the Hard Drive.
            Remove the screws that secure the hard-drive assembly to the computer base.
            Using the pull tab, disconnect the hard-drive cable from the system board.
            Lift the hard-drive assembly off the computer base.
            Remove the screws that secure the hard-drive bracket to the hard drive.
            Lift the hard drive off the hard-drive bracket.
            Disconnect the interposer from the hard drive.
            Connect the new interposer to the new hard drive.
            Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
            Replace the screws that secure the hard-drive bracket to the hard-drive assembly.
            Align the screw holes on the hard-drive assembly to the computer base.
            Replace the screws that secure the hard-drive assembly to the computer base.
            Connect the hard-drive cable to the system board.
