Taking off the front panel is a requirement for replacing any part inside or around the speaker, and if improperly done may lead to damage to the speaker or self.
Use a Jimmy to peel off the screen stuck to the front of the speaker.
Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
Remove ten 6 mm screws using a Phillips #1 screwdriver.
Lift the front panel off of the rest of the device.
Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
Remove the front panel from the device.
