Unscrew the nine PH#0 captive screws on the bottom of the device.
Use a pick to run along the outside of the device popping all the clips. Prying should not be necessary.
Pull carefully, but firmly, on the battery cable until it becomes detached.
Remove these three M2x5 screws and take the battery out
Use a plastic spudger to lift up the flap. Use the flap to pull the connector straight away from the board (towards the battery).
Use a spudger to detach the tab, and pull the tab up away from the device. This will break the adhesive holding in the battery.
