Dell 1350cnw Toner Transfer Roller Replacement
  1. Dell 1350cnw Toner Transfer Roller Replacement, Unclip front top band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Unclip front top band: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
  2. Dell 1350cnw Toner Transfer Roller Replacement, Unclip front top band: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Unclip front top band: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
  3. Dell 1350cnw Toner Transfer Roller Replacement, Remove front top band: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the top of the front band away from the printer and lift away to remove.
  4. Dell 1350cnw Toner Transfer Roller Replacement, Remove left-side top band: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove left-side top band: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove left-side top band: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
  5. Dell 1350cnw Toner Transfer Roller Replacement, Remove control panel module: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove control panel module: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove control panel module: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
  6. Dell 1350cnw Toner Transfer Roller Replacement, Remove front cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front lower flap by carefully bending in the middle and pulling out the locating pins one end at a time.
  7. Dell 1350cnw Toner Transfer Roller Replacement, Remove front cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both 7mm phillips screws securing the front cover in place.
  8. Dell 1350cnw Toner Transfer Roller Replacement, Remove front cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove front cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove front cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the three clips along each end of the front cover by prying outwards and forwards with a prying tool as shown.
  9. Dell 1350cnw Toner Transfer Roller Replacement, Remove front cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide out the bottom edge away from the printer and pull the front cover down away from the top edge to remove.
  10. Dell 1350cnw Toner Transfer Roller Replacement, Remove top cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove top cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Undo both the 5mm M3 phillips screws holding the top cover brackets to the chassis.
  11. Dell 1350cnw Toner Transfer Roller Replacement, Remove top cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove top cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the top cover brackets forwards off the metal frame and lift up to loosen the front edge of the top cover.
  12. Dell 1350cnw Toner Transfer Roller Replacement, Remove top cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the top cover clip off the locating peg at the back of the printer, and lift up the top cover corner.
  13. Dell 1350cnw Toner Transfer Roller Replacement, Remove top cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry apart the back edge of the top cover and the back cover of the printer to unclip the top cover.
  14. Dell 1350cnw Toner Transfer Roller Replacement, Remove top cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the top cover from the control panel corner, pulling towards the back right-hand corner.
    • Note - The top cover should unclip from the back corner with the corner/side piece still attached.
  15. Dell 1350cnw Toner Transfer Roller Replacement, Remove side cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove side cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove side cover: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the back edge of the side cover by prying away from the printer back panel.
    • Pull the top of the side panel away from the printer.
    • Lift up the printer from underneath to release the bottom clips, and the side panel drops away from the printer.
  16. Dell 1350cnw Toner Transfer Roller Replacement, Unplug WiFi module: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the WiFi module plug from the USB/Ethernet board to disconnect.
  17. Dell 1350cnw Toner Transfer Roller Replacement, Remove WiFi module: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove WiFi module: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 7mm phillips screw holding the WiFi module to the printer and remove the WiFi module.
  18. Dell 1350cnw Toner Transfer Roller Replacement, Unplug cables: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Unplug cables: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Unplug cables: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the locking tab to unclip and release the flat flex data cable.
    • Gently pull the flat flex cable out from from the connector.
  19. Dell 1350cnw Toner Transfer Roller Replacement, Unplug cables: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the smaller flat flex cable out from its connector to remove, and repeat for the remaining two connectors.
  20. Dell 1350cnw Toner Transfer Roller Replacement, Remove USB/Ethernet board: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove USB/Ethernet board: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove USB/Ethernet board: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 4mm M3 phillips screw holding the USB connector to the rear cover plate.
    • Unscrew the four 5mm M3 phillips screws holding the USB/Ethernet board to the bracket and remove the board from the printer.
  21. Dell 1350cnw Toner Transfer Roller Replacement, Unscrew fan bracket: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 5mm M3 phillips screw from the fan bracket.
    • Unhook the retaining clip on the lower right-hand side of the fan bracket to loosen from the printer.
  22. Dell 1350cnw Toner Transfer Roller Replacement, Remove fan bracket: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove fan bracket: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove fan bracket: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • De-route the cables from the USB/Ethernet board and remove from the harness on the back of the fan shroud.
    • Pull out the four circled cable connectors to unplug, and de-route the remaining cables from the wiring harness.
    • Lift away the fan/bracket assembly from the printer to remove.
  23. Dell 1350cnw Toner Transfer Roller Replacement, De-route cables: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, De-route cables: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, De-route cables: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out all the indicated cable plugs from the main control board.
    • De-route all the cables from the wiring harness on the side of the printer.
  24. Dell 1350cnw Toner Transfer Roller Replacement, Remove side cable bracket: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove side cable bracket: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove side cable bracket: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push in the retaining pin on the lower right-hand corner of the lower cable bracket, pulling the bracket out slightly away from the printer.
    • Push down the retaining pin on the top left of the cable bracket, and pull down and out from under the USB/Ethernet board support bracket.
    • Pull the cable bracket away from the printer.
  25. Dell 1350cnw Toner Transfer Roller Replacement, Unplug 3-core cable: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Unplug 3-core cable: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the 3-pin connector beneath the main drive motor to unplug.
    • Feed this cable through the cable bracket to separate and remove the cable bracket.
  26. Dell 1350cnw Toner Transfer Roller Replacement, Remove cover plate: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove cover plate: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the flat flex cable to remove from the top of the image output board.
    • Unscrew the four 5mm M3 phillips screws at the corners of the image output board over plate.
  27. Dell 1350cnw Toner Transfer Roller Replacement, Remove flat flex cables: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove flat flex cables: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove flat flex cables: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the retaining bar on each of the five flat flex cable connectors and gently lift out the cable to remove.
  28. Dell 1350cnw Toner Transfer Roller Replacement, Remove USB/Ethernet board bracket: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove USB/Ethernet board bracket: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three 5mm M3 phillips screws holding the USB/Ethernet board bracket to the printer, and remove the bracket.
  29. Dell 1350cnw Toner Transfer Roller Replacement, Remove small gear carrier: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove small gear carrier: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove small gear carrier: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull off the 30mm gear cog.
    • Unscrew both the 5mm M3 phillips screws holding the small gear carrier assembly in place.
    • Tilt the gear carrier away from the printer and remove.
    • Tilting the top edge away first as shown helps stop the gears falling off when removing this part.
  30. Dell 1350cnw Toner Transfer Roller Replacement, Remove motor assembly: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove motor assembly: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove motor assembly: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 5mm M4 phillips screws.
    • Unscrew the 7mm phillips screw.
    • Pull off the 25mm gear. (This usually allows the adjacent gear (green arrow, behind the outer bracket) to come off with the motor/ drive assembly; if it doesn't, this gear can be put back on afterwards).
    • Pull away the main drive motor/gear assembly from the printer to remove.
    • The 25mm drive gear (yellow arrow) and 30mm gear (orange arrow) can be replaced once the motor assembly is removed.
  31. Dell 1350cnw Toner Transfer Roller Replacement, Remove back cover: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 7mm phillips screws holding the rear cover to the printer.
  32. Dell 1350cnw Toner Transfer Roller Replacement, Unplug sensor cable: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Unplug sensor cable: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the connector for the rear cover sensor from the power supply board.
    • De-route the light pink coloured pair of sensor cables and remove from the wiring harness.
  33. Dell 1350cnw Toner Transfer Roller Replacement, Remove back cover: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the rear cover opposite the de-routed cables by prying away from the rest of the printer using a prying tool.
    • The rear cover can now be removed from the printer.
  34. Dell 1350cnw Toner Transfer Roller Replacement, Remove toners & outer cover: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove toners & outer cover: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four toner cartridges from the printer.
    • Slide the outer cover towards the back of the printer to pull out the locating pins and remove.
  35. Dell 1350cnw Toner Transfer Roller Replacement, Remove inner cover: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before proceeding with removing this part, it's worth ensuring the printer is on a wipeable surface or plastic dust sheet, especially if a large amount of loose toner dust is present, as this will tend to make a mess otherwise!
    • Remove the six 7mm phillips screws holding the toner compartment inner cover to the printer.
  36. Dell 1350cnw Toner Transfer Roller Replacement, Remove inner cover: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove inner cover: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove inner cover: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the three connectors for the toner control/ data cables (two from the control board and one from the power supply board) by pulling the connector up from the board.
    • De-route and remove these cables from the front cable guide.
    • Unplug the fuser unit power cable by squeezing the top of the retaining clip and pulling the connectors up from the power supply board.
    • De-route the fuser unit power cable from the cable guide on the back of the inner toner cover.
  37. Dell 1350cnw Toner Transfer Roller Replacement, Remove inner cover: crwdns2935265:037crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove inner cover: crwdns2935265:037crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove inner cover: crwdns2935265:037crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push down on the power switch retaining bracket to release the cover from the switch.
    • Pull the toner compartment inner cover away from the printer, taking care to lift the cover over the springs passing through it (otherwise these may drop more toner dust), to remove the toner inner cover assembly.
  38. Dell 1350cnw Toner Transfer Roller Replacement, Remove outer gear carrier: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove outer gear carrier: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove outer gear carrier: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three 5mm M4 phillips screws.
    • Unscrew the two 7mm phillips screws.
    • Pull the outer gear carrier assembly away from the printer to remove.
  39. Dell 1350cnw Toner Transfer Roller Replacement, Remove solenoid: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove solenoid: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove solenoid: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 7mm phillips screw holding the solenoid in place.
    • Pull the solenoid bracket off the mounting pins to remove from the printer.
  40. Dell 1350cnw Toner Transfer Roller Replacement, Remove control board: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove control board: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug all remaining cables from the control board.
    • Unscrew the four 5mm M3 phillips screws from the corners.
    • Lift out the PCB to remove.
  41. Dell 1350cnw Toner Transfer Roller Replacement, Remove main gear carrier: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove main gear carrier: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 5mm M3 phillips screws.
    • Unscrew the six 7mm phillips screws (the top left one is hidden behind the 25mm gear in the photo).
    • Pull away the gear carrier to remove from the printer.
  42. Dell 1350cnw Toner Transfer Roller Replacement, Remove power supply board: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove power supply board: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove power supply board: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push in the retaining clip and pull out the AC input power connector from the power supply board.
    • Pull out the 4-pin output power connector from the opposite end of the board.
    • Unscrew the four 5mm M3 phillips screws and lift the power supply board up from the printer.
  43. Dell 1350cnw Toner Transfer Roller Replacement, Remove front cable bracket: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove front cable bracket: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Remove front cable bracket: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 5mm M4 phillips screw attaching the mains earth cable to the chassis.
    • Unscrew the 5mm M3 phillips screw at each end of the cable bracket.
    • Pull the bracket away from the printer to remove.
  44. Dell 1350cnw Toner Transfer Roller Replacement, De-route rear cover cables: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, De-route rear cover cables: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, De-route rear cover cables: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • De-route the CTD/ADC sensor cables from within the rear cover of the printer.
    • Pull through the cable and connector.
  45. Dell 1350cnw Toner Transfer Roller Replacement, Unscrew core printing assembly: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Unscrew core printing assembly: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the pair of 7mm phillips screws on each side of the core printing assembly.
  46. Dell 1350cnw Toner Transfer Roller Replacement, Lift out core printing assembly: crwdns2935265:046crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Lift out core printing assembly: crwdns2935265:046crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull forward the front frame slightly away from the core printing assembly.
    • Lift up the core printing assembly from the front edge first, and lift away from the rest of the printer to remove.
  47. Dell 1350cnw Toner Transfer Roller Replacement, Unhook end springs: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Unhook end springs: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up and unhook the spring at each end of the toner roller unit.
  48. Dell 1350cnw Toner Transfer Roller Replacement, Unclip flat flex cable: crwdns2935265:048crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift out any flat flex cables required to access the toner roller unit being removed.
  49. Dell 1350cnw Toner Transfer Roller Replacement, Unclip & remove toner roller: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Unclip & remove toner roller: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Toner Transfer Roller Replacement, Unclip & remove toner roller: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a prying tool or small flat-bladed screwdriver to lift up the retaining clip at either end of the toner roller unit, and lift off the toner roller from the printing assembly.
Jac
crwdns2935283:010/08/24crwdne2935283:0
2.728 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 49
