Dell 1350cnw Rotary Sensor Replacement
  1. Dell 1350cnw Rotary Sensor Replacement, Unclip front top band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Unclip front top band: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
  2. Dell 1350cnw Rotary Sensor Replacement, Unclip front top band: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Unclip front top band: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
  3. Dell 1350cnw Rotary Sensor Replacement, Remove front top band: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the top of the front band away from the printer and lift away to remove.
  4. Dell 1350cnw Rotary Sensor Replacement, Remove left-side top band: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove left-side top band: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove left-side top band: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
  5. Dell 1350cnw Rotary Sensor Replacement, Remove control panel module: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove control panel module: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove control panel module: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
  6. Dell 1350cnw Rotary Sensor Replacement, Remove front cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front lower flap by carefully bending in the middle and pulling out the locating pins one end at a time.
  7. Dell 1350cnw Rotary Sensor Replacement, Remove front cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both 7mm phillips screws securing the front cover in place.
  8. Dell 1350cnw Rotary Sensor Replacement, Remove front cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove front cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove front cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the three clips along each end of the front cover by prying outwards and forwards with a prying tool as shown.
  9. Dell 1350cnw Rotary Sensor Replacement, Remove front cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide out the bottom edge away from the printer and pull the front cover down away from the top edge to remove.
  10. Dell 1350cnw Rotary Sensor Replacement, Remove top cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove top cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Undo both the 5mm M3 phillips screws holding the top cover brackets to the chassis.
  11. Dell 1350cnw Rotary Sensor Replacement, Remove top cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove top cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the top cover brackets forwards off the metal frame and lift up to loosen the front edge of the top cover.
  12. Dell 1350cnw Rotary Sensor Replacement, Remove top cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the top cover clip off the locating peg at the back of the printer, and lift up the top cover corner.
  13. Dell 1350cnw Rotary Sensor Replacement, Remove top cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry apart the back edge of the top cover and the back cover of the printer to unclip the top cover.
  14. Dell 1350cnw Rotary Sensor Replacement, Remove top cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the top cover from the control panel corner, pulling towards the back right-hand corner.
    • Note - The top cover should unclip from the back corner with the corner/side piece still attached.
  15. Dell 1350cnw Rotary Sensor Replacement, Remove side cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove side cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove side cover: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the back edge of the side cover by prying away from the printer back panel.
    • Pull the top of the side panel away from the printer.
    • Lift up the printer from underneath to release the bottom clips, and the side panel drops away from the printer.
  16. Dell 1350cnw Rotary Sensor Replacement, Unplug WiFi module: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the WiFi module plug from the USB/Ethernet board to disconnect.
  17. Dell 1350cnw Rotary Sensor Replacement, Remove WiFi module: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove WiFi module: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 7mm phillips screw holding the WiFi module to the printer and remove the WiFi module.
  18. Dell 1350cnw Rotary Sensor Replacement, Unplug cables: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Unplug cables: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Unplug cables: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the locking tab to unclip and release the flat flex data cable.
    • Gently pull the flat flex cable out from from the connector.
  19. Dell 1350cnw Rotary Sensor Replacement, Unplug cables: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the smaller flat flex cable out from its connector to remove, and repeat for the remaining two connectors.
  20. Dell 1350cnw Rotary Sensor Replacement, Remove USB/Ethernet board: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove USB/Ethernet board: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove USB/Ethernet board: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 4mm M3 phillips screw holding the USB connector to the rear cover plate.
    • Unscrew the four 5mm M3 phillips screws holding the USB/Ethernet board to the bracket and remove the board from the printer.
  21. Dell 1350cnw Rotary Sensor Replacement, Unscrew fan bracket: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 5mm M3 phillips screw from the fan bracket.
    • Unhook the retaining clip on the lower right-hand side of the fan bracket to loosen from the printer.
  22. Dell 1350cnw Rotary Sensor Replacement, Remove fan bracket: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove fan bracket: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove fan bracket: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • De-route the cables from the USB/Ethernet board and remove from the harness on the back of the fan shroud.
    • Pull out the four circled cable connectors to unplug, and de-route the remaining cables from the wiring harness.
    • Lift away the fan/bracket assembly from the printer to remove.
  23. Dell 1350cnw Rotary Sensor Replacement, De-route cables: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, De-route cables: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, De-route cables: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out all the indicated cable plugs from the main control board.
    • De-route all the cables from the wiring harness on the side of the printer.
  24. Dell 1350cnw Rotary Sensor Replacement, Remove side cable bracket: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove side cable bracket: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove side cable bracket: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push in the retaining pin on the lower right-hand corner of the lower cable bracket, pulling the bracket out slightly away from the printer.
    • Push down the retaining pin on the top left of the cable bracket, and pull down and out from under the USB/Ethernet board support bracket.
    • Pull the cable bracket away from the printer.
  25. Dell 1350cnw Rotary Sensor Replacement, Remove cover plate: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove cover plate: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the flat flex cable to remove from the top of the image output board.
    • Unscrew the four 5mm M3 phillips screws at the corners of the image output board over plate.
  26. Dell 1350cnw Rotary Sensor Replacement, Remove flat flex cables: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove flat flex cables: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove flat flex cables: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the retaining bar on each of the five flat flex cable connectors and gently lift out the cable to remove.
  27. Dell 1350cnw Rotary Sensor Replacement, Remove USB/Ethernet board bracket: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove USB/Ethernet board bracket: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three 5mm M3 phillips screws holding the USB/Ethernet board bracket to the printer, and remove the bracket.
  28. Dell 1350cnw Rotary Sensor Replacement, Remove small gear carrier: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove small gear carrier: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove small gear carrier: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull off the 30mm gear cog.
    • Unscrew both the 5mm M3 phillips screws holding the small gear carrier assembly in place.
    • Tilt the gear carrier away from the printer and remove.
    • Tilting the top edge away first as shown helps stop the gears falling off when removing this part.
  29. Dell 1350cnw Rotary Sensor Replacement, Remove motor assembly: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove motor assembly: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove motor assembly: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 5mm M4 phillips screws.
    • Unscrew the 7mm phillips screw.
    • Pull off the 25mm gear. (This usually allows the adjacent gear (green arrow, behind the outer bracket) to come off with the motor/ drive assembly; if it doesn't, this gear can be put back on afterwards).
    • Pull away the main drive motor/gear assembly from the printer to remove.
    • The 25mm drive gear (yellow arrow) and 30mm gear (orange arrow) can be replaced once the motor assembly is removed.
  30. Dell 1350cnw Rotary Sensor Replacement, Remove solenoid: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove solenoid: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 7mm phillips screw holding the solenoid bracket in place.
    • Use prying tool (or flat screwdriver) to pry the solenoid bracket forward off it's aligning pins to remove.
  31. Dell 1350cnw Rotary Sensor Replacement, Remove sprung gear: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove sprung gear: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove sprung gear: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unhook the gear spring by pulling the end and lifting over the retaining hook.
    • Use a small prying tool or flat-blade screwdriver to lift up & hold the retaining clip.
    • Pull the gear away from the printer to remove.
  32. Dell 1350cnw Rotary Sensor Replacement, Remove rotary sensor: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove rotary sensor: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Rotary Sensor Replacement, Remove rotary sensor: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the rotary sensor off using prying tool to assist if required.
    • Carefully pull the cable through the printer to remove the rotary sensor.
Jac
crwdns2935283:010/08/24crwdne2935283:0
2,728 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 35
