Dell 1350cnw Fan Replacement
  1. Dell 1350cnw Fan Replacement, Unclip front top band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Fan Replacement, Unclip front top band: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
  2. Dell 1350cnw Fan Replacement, Unclip front top band: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Fan Replacement, Unclip front top band: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
  3. Dell 1350cnw Fan Replacement, Remove front top band: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the top of the front band away from the printer and lift away to remove.
  4. Dell 1350cnw Fan Replacement, Remove left-side top band: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Fan Replacement, Remove left-side top band: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Fan Replacement, Remove left-side top band: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
  5. Dell 1350cnw Fan Replacement, Remove control panel module: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Fan Replacement, Remove control panel module: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Fan Replacement, Remove control panel module: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
  6. Dell 1350cnw Fan Replacement, Remove front cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front lower flap by carefully bending in the middle and pulling out the locating pins one end at a time.
  7. Dell 1350cnw Fan Replacement, Remove front cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both 7mm phillips screws securing the front cover in place.
  8. Dell 1350cnw Fan Replacement, Remove front cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Fan Replacement, Remove front cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Fan Replacement, Remove front cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the three clips along each end of the front cover by prying outwards and forwards with a prying tool as shown.
  9. Dell 1350cnw Fan Replacement, Remove front cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide out the bottom edge away from the printer and pull the front cover down away from the top edge to remove.
  10. Dell 1350cnw Fan Replacement, Remove top cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Fan Replacement, Remove top cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Undo both the 5mm M3 phillips screws holding the top cover brackets to the chassis.
  11. Dell 1350cnw Fan Replacement, Remove top cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Fan Replacement, Remove top cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the top cover brackets forwards off the metal frame and lift up to loosen the front edge of the top cover.
  12. Dell 1350cnw Fan Replacement, Remove top cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the top cover clip off the locating peg at the back of the printer, and lift up the top cover corner.
  13. Dell 1350cnw Fan Replacement, Remove top cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry apart the back edge of the top cover and the back cover of the printer to unclip the top cover.
  14. Dell 1350cnw Fan Replacement, Remove top cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the top cover from the control panel corner, pulling towards the back right-hand corner.
    • Note - The top cover should unclip from the back corner with the corner/side piece still attached.
  15. Dell 1350cnw Fan Replacement, Remove side cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Fan Replacement, Remove side cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell 1350cnw Fan Replacement, Remove side cover: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the back edge of the side cover by prying away from the printer back panel.
    • Pull the top of the side panel away from the printer.
    • Lift up the printer from underneath to release the bottom clips, and the side panel drops away from the printer.
  16. Dell 1350cnw Fan Replacement, Unplug fan power cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the fan power cable connector from the power supply board and de-route the cable.
  17. Dell 1350cnw Fan Replacement, Unclip fan: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell 1350cnw Fan Replacement, Unclip fan: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull both the retaining clips away from the fan, and pull the fan out from the housing to remove.
Jac
crwdns2935283:010/08/24crwdne2935283:0
2.728 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 26
