Definitive Technology W7 Speaker Replacement
  1. Definitive Technology W7 Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the metal spudger to pry off the panel at the top of the device.
    • The top panel has the device logo in the center.
    • Use the flat end of the metal spudger and place it between the gaps of the top panel and slowly pry the panel off.
  2. Definitive Technology W7 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the thirteen Phillips #0 screws.
  3. Definitive Technology W7 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black panel.
  4. Definitive Technology W7 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Definitive Technology W7 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After you remove the black panel, you will see that the device is covered with a gray mesh, secured with a drawstring.
    • Flick the switch on the middle of the lock down to loosen the sack.
  5. Definitive Technology W7 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After you have flicked the switch loosen the sack and pull the sack down which will reveal the speaker.
  6. Definitive Technology W7 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws on top of the device on each corner with a Phillips #0 screwdriver.
  7. Definitive Technology W7 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the top cover off the device.
  8. Definitive Technology W7 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you now look inside the device, you will see the speaker which is the large cylinder on the inner side of the device.
  9. Definitive Technology W7 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Definitive Technology W7 Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four Phillips #0 screws around the speaker holding it in place.
    • Now lay the device on its side with the speaker facing upward, then unscrew the screws around the speaker.
  10. Definitive Technology W7 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Stand the device upright and carefully pull the speaker out of the device with the wires still intact.
  11. Definitive Technology W7 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now grab the end of the wire connecting the device to the speaker itself.
    • Slowly and carefully pull the wires away from the speaker.
Jamari Brewster
crwdns2935283:010/26/22crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Petersen Fall 2022 crwdns2935289:0UMass Dartmouth, Team 2-5, Petersen Fall 2022crwdne2935289:0
UMASSD-PETERSEN-F22S2G5
crwdns2942667:0crwdne2942667:0 470
