Deep Cleaning a Honeywell HYF260 Tower Fan
  1. Deep Cleaning a Honeywell HYF260 Tower Fan, Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan, Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start with turning the fan on its side along the floor.
  2. Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist the red locking mechanism at the bottom to the left. It should come off with ease, and the base should detach afterwards.
  3. Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Two screws will be revealed, which will need to be screwed off by your TORX Allan Wrench. Do the same to the screw located on the back-middle of the tower.
    • Red circles will indicate TORX screws going forward!
  4. Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the top of the back, there are four additional screws, which will need to be screwed off with a Phillips Screwdriver.
    • Green circles will indicate Phillips screws going forward!
  5. Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the screws are removed, the top can be lifted, revealing more screws. Remove the ones outlined so the top comes off more easily.
    • Ignore the four small ones on the top part! This isn’t necessary for cleaning- that contains the control panel.
  6. Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The two halves of the cage should now safely come apart with a bit of force. BE VERY CAREFUL IN ORDER NOT TO SNAP ANY PLASTICS!
  7. Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin unscrewing the interior mechanisms with your screwdrivers. The necessary ones are all outlined!
    • I recommend setting aside which screws go where in relation to the part and its location, as it’ll make putting the fan back together much easier!
  8. Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You should now be able to remove the blade cylinder and its connector, as well as the drum, which is outlined by the blue square. This will leave behind the motor disc.
    • When completing the steps in reverse after cleaning, lubricating the drum is highly recommended to prevent rattling!
  9. Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the motor disc and its attachments, setting them aside for gentle cleaning.
    • Make sure to maintain the positioning of the wires along the side of the cage when removing everything!
  10. Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin cleaning! Pictured is the cleaning of half of the cage as an example. I used a handheld vacuum attachment, a damp towel followed by a dry one, and finally cotton swabs to get between the harder-to-reach areas.
    • To prevent damage to the mechanisms like the motor disc and the drum, be very gentle with them! The vacuum should only be used for the cage.
  11. Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Deep Cleaning a Honeywell HYF260 Tower Fan: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once everything is free of junk, you can now put the fan back together, following the steps taken in reverse! You should now be left with a clean and better-functioning fan.
    • If rattling is heard, you may need to disassemble it once more and make sure the screws are tightened, the mechanisms are properly in-place, and that the drum is properly lubricated.
Gav
crwdns2935283:003/12/25crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 2-2, Kapoor Spring 2025 crwdns2935289:0Austin Community College, Team 2-2, Kapoor Spring 2025crwdne2935289:0
AUSTINCC-KAPOOR-S25S2G2
crwdns2936753:07crwdne2936753:0 61
crwdns2936753:030crwdne2936753:0 264
crwdns2942667:0crwdne2942667:0 1,258
