This guide demonstrates how to replace the Voltage Sensitivity Relay (VSR) for the DeWalt DW938.
Use a torque bit screw driver to remove the T10 18.3 mm screw on the handle.
Use a torque bit screw driver to remove 6 T10 21.5 mm screws on the handle.
Carefully cut the safety sticker with a blade along the seam.
Remove the Clam Shell from the handle unit.
Lift the mechanical device off the pins of the clam shell.
Remove the red and black trigger wires from the brush leads with the pliers.
Remove the VSR trigger and the lock button.
