DeWalt DW920 Motor Replacement
  1. DeWalt DW920 Motor Replacement, Trigger: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the four screws to open up the case.
    • Ensure that the drill is unplugged and remove the battery to avoid electrical shock or accidental activation.
  2. DeWalt DW920 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the outer housing to reveal the screws that are used to connect the outer covering of the drill.
    • Use a Phillips #2 screwdriver to remove all the screws that join the two parts of the casing.
    • Take the two halves of the housing and carefully pry them apart.
    • Make sure not to touch any parts in the interior of the screwdriver.
  3. DeWalt DW920 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find and replace the old trigger. The trigger assembly should be found inside the drill.
    • The trigger is the component affixed to the motor and the wires. Loosen the wiring of the trigger carefully so that you can separate the connections of the terminals.
    • Remove the wires. Then take a picture so that you can remember how they should be connected. Pull the old trigger out from its engagement with the housing.
  4. DeWalt DW920 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the new trigger. Place the new trigger in the position within the housing where the old trigger originated from.
    • Solder the wires together by placing the terminal in the connector.
    • Check the wire connections with the help of the photo which was taken earlier, if it is necessary.
    • Make sure the trigger is locked tightly in its position.
  5. DeWalt DW920 Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reassemble the drill align the two halves of the housing back in their original positions, making sure that the internal parts, and in particular the trigger, are correctly positioned.
    • Put the screws back into their respective holes and fasten them with the Phillips #2 screwdriver.
    • Screw the nuts at an angle to make sure it will tightening uniformly.
  6. DeWalt DW920 Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Test the trigger either by connecting the battery again or plugging the drill back in.
    • Pull the trigger to make the drill glide and to engage the rig. If it will not operate correctly, retract and examine its wiring and the position of the trigger.
    • If you meet any problems or have troubles with the trigger, don’t force it. Go back to the previous steps.
  7. DeWalt DW920 Motor Replacement, Motor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motor and trigger mechanism out from the frame of the drill.
  8. DeWalt DW920 Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
    • Mark where the two cables were connected using masking tape.
    • Solder the new motor assembly wires to the trigger mechanism.
  • Follow the case replacement guide for how to replace the case on the drill.
  • The trigger replacement guide is located above.
  • To reassemble the device, follow the instructions in reverse.
Stephen Rada
crwdns2935283:003/11/16crwdne2935283:0
433 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 8-2, Botvin Spring 2016 crwdns2935289:0UMass Dartmouth, Team 8-2, Botvin Spring 2016crwdne2935289:0
UMASSD-BOTVIN-S16S8G2
crwdns2942667:0crwdne2942667:0 989
