For this guide you will not need any additional tools. By following the basic steps you should be able to remove the battery so a new functioning one can be installed.
Firmly grip the handle of the drill with one hand and the battery with the other.
Using the hand holding the battery press the two tabs that are located on the left and right side of the battery where it connects to the drill.
With the two tabs pushed in pull the battery out of the drill.
Need batteries for DW920 dewalt screwdriver
I have case, charger and screwdriver but batteries are dead and need replacements (2)
Cell 747-294-1342 Chuck P.
