DeWalt DCD771C2 Chuck Replacement
  1. DeWalt DCD771C2 Chuck Replacement, Chuck: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the chuck until it is all of the way open.
  2. DeWalt DCD771C2 Chuck Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T20 screwdriver to remove the screw in the center of the chuck.
    • This screw is left-hand threaded, so you will need to turn clockwise to remove the screw, rather than counter-clockwise.
  3. DeWalt DCD771C2 Chuck Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeWalt DCD771C2 Chuck Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeWalt DCD771C2 Chuck Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now take a 8mm or larger Allen Wrench with your dominant hand, and insert it into the chuck.
    • Spin the chuck clockwise to tighten the allen inside as tight as it will go.
    • Set the gear box selector switch on the top of the drill to 1.
  4. DeWalt DCD771C2 Chuck Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeWalt DCD771C2 Chuck Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeWalt DCD771C2 Chuck Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With your nondominant hand lay the drill flat on the edge of a table such that chuck hangs off the edge. Hold the head of the drill tightly pushing it against the table (not the part with the battery).
    • With your dominant hand, take a rubber mallet and strike the Allen Wrench hard. You want to hit the Allen wrench so that it will move counterclockwise in reference to someone looking at the face of the chuck.
    • It may take more than one hit but the chuck will spin easily once broken free of the threads of the drill spindle. Use the Allen wrench to spin the chuck counterclockwise until separated from the drill.
    I have this exact drill and the chuck loosens up after using the drill for a few times. It’s almost like the drill brakes too fast and the momentum continues to through the chuck to loosen it. Will replacing the chuck fix my issue?
    shawoo - crwdns2934203:0crwdne2934203:0
    @shawoo: Your chuck should be tighten, not changed.
    If you follow this guide to change the chuck you might destroy the gearcase.
    You need a special tool to change this the right way.
    Øyvind Brakestad - crwdns2934203:0crwdne2934203:0
    I have followed your advice but my chuck keeps skipping and won't break free, what do you recommend I do now?
    Don Godin - crwdns2934203:0crwdne2934203:0
Emily Passey
crwdns2935283:004/12/16crwdne2935283:0
354 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-5, Maness Spring 2016 crwdns2935289:0Cal Poly, Team 25-5, Maness Spring 2016crwdne2935289:0
CPSU-MANESS-S16S25G5
crwdns2947412:010crwdne2947412:0
My chuck is ceased in the closed position and I am unable to open it.
Is there any way to open it ?
davidcartwright4155 - crwdns2934203:0crwdne2934203:0
My chuck was stuck partially open. Could not back the retaining screw all the way out. I had to cut the chuck off with a grinder.
Gary Panepinto -
Horrible directions. “Toward you” doesn’t make sense. Establish a frame of reference (facing the chuck) and state clockwise and counter-clockwise. That does make sense.
EDMOND THOMPSON - crwdns2934203:0crwdne2934203:0
My drill has a hex screw holding the chuck on… not a Phillips screw shown in the videos. I cannot get the 7/64 Allen wrench to loosen the “reverse thread” screw. Afraid I will break the Allen wrench.
Dwayne - crwdns2934203:0crwdne2934203:0
I have removed the set screw from the chuck, installed a large Allen key tightened the Chuck, smacked it with a rubber mallet as hard as possible, the chuckwill not come free, just ratchets. What is the next step?
chuck will not loosen,has drill bit in it. what next?
agas41willys - crwdns2934203:0crwdne2934203:0
My drill don’t have a screw in the chuck.so how do I replace my chuck
ebev1600 - crwdns2934203:0crwdne2934203:0
Emily ain't answering any questions. Do any of you readers know of another site? I'm banging the Allen wrench clockwise with no results!?!
JP Lutz - crwdns2934203:0crwdne2934203:0
Step 3 should say: "Set the chuck to the HIGHEST SETTING" and strike the Allen Wrench COUNTER CLOCKWISE."
I finally did that and the chuck came loose after 3 blows from the mallet. JPL
My chuck for the DW593 is stuck in the open position and will not open or close. How do I get the old chuck off to be able to install a new chuck. there is no set screw to take out as some repair videos propose.
ERIC L TYRA - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 57
crwdns2936753:030crwdne2936753:0 281
crwdns2942667:0crwdne2942667:0 24,142
