If the motor of your drill is not operating properly or not operating at all, this guide will show you how to replace the motor of your drill.
Compress the buttons on either side of the battery and lift the drill away from battery.
Remove the eight 16 mm, Torx Security #15 screws.
Lay the drill on its side and gently lift the top half off it.
Lift drill mechanism out of the shell.
Desolder the red and black wires from the motor.
Learn more about soldering here.
Slightly twist and pull motor away from the clutch.
Unplug the wires from the trigger switch....don't unsolder.
New motor comes with wires.
allen.anderson1 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks for the heads up on the wires
Daniel Randall - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Is there a fix to replace brushes?
pmac086 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
