If you are having trouble controlling the speed of the drill there may be a problem with your clutch. By following this guide you will learn how to replace it.
Compress the buttons on either side of the battery and lift the drill away from battery.
Remove the eight 16 mm, Torx Security #15 screws.
Lay the drill on its side and gently lift the top half off it.
Lift drill mechanism from the drill assembly.
Twist slightly and pull clutch away from motor.
Remove clutch.
worthless no info about clutch
I second the comment from bowlweevil, you dont even open up the clutch...
