DeWalt DC970 Battery Cells Replacement
crwdns2942287:0crwdne2942287:0If the battery of your drill is not giving the drill power, a problem you could have is deteriorated battery cells. This guide will show you how to replace the battery cells.
crwdns2944105:0crwdne2944105:0
Compress the buttons on either side of the battery and lift the drill away from battery.
Remove the six 19 mm, Torx Security 15 screws from the top of the battery.
Pull off the battery cover, exposing the battery cells.
Remove the old battery cells by slowly pulling them out of the top piece of the battery.
Thanks for the instruction. Looks easy enough. But where do you get the replacement cells? Looks like there are many replacement complete battery packs. So far I haven’t found just the cells. Anyone have a clue?
crwdns2935229:05crwdne2935229:0
It is not clear from the guide if it is all cells that are replaced or single cells.
If single cells, it would be very nice if instructions were shown how to test each cell, and replace single cells.
/Søren
Where can one get the replacement cells?
