DeWalt D28110 Power Switch Replacement
  1. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Gear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeWalt D28110 Power Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the gear case.
  3. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
  4. DeWalt D28110 Power Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the edge of the spudger to loosen and remove the back panel.
  5. DeWalt D28110 Power Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 20-mm torx screw holding the rear panel in place.
  6. DeWalt D28110 Power Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull back the rear side of the back panel.
  7. DeWalt D28110 Power Switch Replacement, Power Switch: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeWalt D28110 Power Switch Replacement, Power Switch: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeWalt D28110 Power Switch Replacement, Power Switch: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is an inner plastic guard behind the motor shaft.
    • Unscrew the four screws at each corner.
    • The guard should pull out with a good firm tug.
  8. DeWalt D28110 Power Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeWalt D28110 Power Switch Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeWalt D28110 Power Switch Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Just behind the inner guard is the button slide.
    • Use needle nose pliers to pinch and push the button's flanges together, and out of the slot.
  9. DeWalt D28110 Power Switch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeWalt D28110 Power Switch Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeWalt D28110 Power Switch Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the J-1 screwdriver, unscrew the power cord wires from the red switch box (located in the back of the grinder).
  10. DeWalt D28110 Power Switch Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeWalt D28110 Power Switch Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the motor wires from the other side of the switch box.
    • They wires are connected as a sleeve to the flat pin out of the switch box. A firm pull should do it.
Kean Wee
crwdns2935283:001/22/15crwdne2935283:0
495 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-6, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 18-6, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S18G6
Very clear and concise guide with relevent pictures. Very well done, thank you
Michael Creel - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,269
