This guide will take you through removing the back panel assembly and disconnecting the power cable from the inner electric components.
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
Use the edge of the spudger to loosen and remove the back panel.
Remove the single 20-mm torx screw holding the rear panel in place.
Pull back the rear side of the back panel.
Locate the red switch box.
Using the J-10 screwdriver, unscrew the screws and detach the wires.
Unthread the two wires from the power cord clamp.
