In this guide you will take apart the pinion "head" of the grinder to gain access to components in the gear case.
Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
Using the T-15 screwdriver, remove the four torx screws.
Remove the gear case cover from the gear case.
Using a 10-mm wrench, remove the hex nut by rotating counter-clockwise.
Remove the armature assembly from the gear case.
Remove the pinion from the armature assembly.
