This guide will walk you through replacing the brush and spring components of the grinder. These are both located at the base of the brush motor and can be easily replaced.
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
Use the edge of the spudger to loosen and remove the back panel.
Remove the single 20-mm torx screw holding the rear panel in place.
Pull back the rear side of the back panel.
Gently pull to disconnect brush connector.
Use the edge of the spudger to slide the spring off its post.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to gently remove the brush and cable.
