Unfortunately, the upper piston is not reached by the descaling and cleaning program. If it is dirty/calcified, the machine will no longer function properly. It can be replaced or revised. This is shown here.
Remove all coffee beans. Remove all attachments such as drip tray, milk frother and water tank. Open the service door and remove the brew group.
Unscrew the two Phillips screws
The Phillips screw under the water tank can remain.
The bean compartment flap must be removed. It is latched on the left and right, the latch is held under tension by a spring. Compress the spring until the catch is free and lift off the flap.
There is a plastic cover strip under the flap. It is only latched in place. Release it with a flat tool and lift it out.
Lift the back side up and put it aside.
The side covers are still attached to the back with two screws. They are located under a cover strip that is only snapped in place. Take off the cover strip and put it aside.
Unscrew the two Phillips screws.
Push the left side panel back about 1 cm. It often jams strongly and you have to help it with a plastic opening tool.
Remove the left side panel.
The right side panel is removed in the same way, but the service hatch is a bit obstructive. Open it first and push the side panel back a few millimeters. This is often difficult and you will need a plastic lever tool.
Close the flap again and push the sides further back. It is a bit tricky and you have to work carefully. Lift out the side panel.
Some devices have a warming plate. Disconnect the flat plugs on the green/yellow protective earth conductors.
The top is fixed with screws on the left and right, depending on the type. Unscrew them.
Now the top can be gently lifted off.
First loosen the detent on the edge. Use a thin flat-blade screwdriver to drive under the latch from behind. Insert a strong plastic lever tool into the gap between the control panel and the front. The latch opens with a loud crack.
Now you can open the other latches with the lever tool
Lift up the control panel a little. Press the latch on the white plug and pull off the plug.
Unthread the ribbon cable that leads to the control electronics at the back as far as possible. This will make it longer and you can place the control panel on its side.
Pull out the clip at the top left and loosen the pressure line. Pay attention to the O-ring. It either hangs on the line or afterwards. When reassembling, replace it with a new one if possible.
Pull out the clamp in the middle and loosen the pressure line. Pay attention to the O-ring. It either hangs on the line or afterwards. When reassembling, replace it with a new one if possible.
Pull out the clamp on the bottom left and loosen the pressure line. Pay attention to the O-ring. It either hangs on the line or afterwards. When reassembling, replace it with a new one if possible.
Disconnect the two spade connectors from the microswitch
Take off the black bend protector on the middle pressure line.
Unscrew the two Allen screws (4 mm).
Lift off the stainless steel bracket.
Unscrew the Phillips screw on the black protective plate on the left and pull off the protective plate.
Using a flat tool, disconnect the drain hose on the left.
Remove the two Phillips screws securing the side of the upper piston support plate.
Pull off the hose to the coffee spout.
Pull out the pressure hoses that are in the way,through the openings on the left.
The upper piston support plate is now free. However, it is very tight and it is tricky to get it out. Be patient and work carefully. Make sure that the ribbon cable to the control panel is not damaged.
The piston is attached to the gray plastic part with a small ring retainer. Push the fuse to the side and store it well.
Turn the piston around. There is a recessed Torx T10 screw in the exact center. Unscrew it.
Unscrew the two Phillips screws on the piston and remove the black cover.
Remove the large O-ring on the piston.
Unscrew the single Phillips head screw in the center of the piston.
Gently pull off the plunger. Note the springs inside.
Turn the piston over and remove the attachments:
Unscrew the two Phillips screws on the valve and remove the valve.
Unscrew the two Allen screws (2 mm) on the raccord and remove the raccord.
Unscrew the single Phillips head screw on the microswitch and lift the microswitch out.
Thoroughly degrease and descale all parts. If possible, replace the O-rings. Re-grease them and reassemble the upper piston.
The maintenance kit contains a total of 18 seals for the upper piston, plus two for the lower piston.
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
