DeLonghi ETAM Opening side panels
  1. DeLonghi ETAM Opening side panels, DeLonghi ETAM Opening side panels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ETAM Opening side panels, DeLonghi ETAM Opening side panels: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the power plug and remove the power cord from the device.
    • Remove all coffee beans. Remove all attachments such as drip tray, milk frother and water tank. Open the service door and remove the brew group.
    • Unscrew the two Phillips screws
    • The Phillips screw under the water tank can remain.
  2. DeLonghi ETAM Opening side panels: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ETAM Opening side panels: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The bean compartment flap must be removed. It is latched on the left and right, the latch is held under tension by a spring. Compress the spring until the catch is free and lift off the flap.
  3. DeLonghi ETAM Opening side panels: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ETAM Opening side panels: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ETAM Opening side panels: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is a plastic cover strip under the flap. It is only latched in place. Release it with a flat tool and lift it out.
  4. DeLonghi ETAM Opening side panels: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ETAM Opening side panels: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the back side up and put it aside.
  5. DeLonghi ETAM Opening side panels: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ETAM Opening side panels: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The side covers are still attached to the back with two screws. They are located under a cover strip that is only snapped in place. Take off the cover strip and put it aside.
    • Unscrew the two Phillips screws.
  6. DeLonghi ETAM Opening side panels: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ETAM Opening side panels: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the left side panel back about 1 cm. It often jams strongly and you have to help it with a plastic opening tool.
    • Remove the left side panel.
  7. DeLonghi ETAM Opening side panels: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The right side panel is removed in the same way, but the service hatch is a bit obstructive. Open it first and push the side panel back a few millimeters. This is often difficult and you will need a plastic lever tool.
    • Close the flap again and push the sides further back. It is a bit tricky and you have to work carefully. Lift out the side panel.
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0shinglecrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
293.806 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2936753:030crwdne2936753:0 95
crwdns2942667:0crwdne2942667:0 1,815
