DeLonghi ECAM series grinder replace
  1. DeLonghi ECAM series grinder replace, DeLonghi ECAM back panel removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power cord!
    • Remove all attachments such as water tank, pulp drawer, brew group.
    • Turn the machine with the back facing you.
    • Remove five Torx T20 security screws.
    • A small hurdle: These screws have a pin in the middle, so the screwdriver must have a hole.
  2. DeLonghi ECAM series grinder replace: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ECAM series grinder replace: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift out the back.
    • The following components are immediately visible:
    • grinder
    • pump
    • flowmeter
  3. DeLonghi ECAM series grinder replace, DeLonghi ECAM Series left side panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM series grinder replace, DeLonghi ECAM Series left side panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM series grinder replace, DeLonghi ECAM Series left side panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the side panel back about 1.5 cm.
    • Lift off the panel.
    • The following compononents are exposed:
    • Heater
    • Expansion chamber
    • Gear drive
    • Steam valve
  4. DeLonghi ECAM series grinder replace, Remove DeLonghi ECAM series top cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM series grinder replace, Remove DeLonghi ECAM series top cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM series grinder replace, Remove DeLonghi ECAM series top cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Depending on the model, the steam tap/water spout must be removed, there are slight differences here.
    • Pull out the plastic clip on the steam nozzle.
    • Pull the steam nozzle out towards you.
  5. DeLonghi ECAM series grinder replace: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ECAM series grinder replace: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull off the steam faucet toggle. Only use a plastic tool to pry to avoid damaging the bezel.
  6. DeLonghi ECAM series grinder replace: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM series grinder replace: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM series grinder replace: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you haven't already done so, also detach the right-hand cover on the water tank.
    • Remove the four Phillips screws securing the top cover.
    • Lift the top cover up a bit. That might be a bit sticky.
    • Don't remove the top cover completely, some models still have cables attached to the cup warmer.
    • If there is a cup warmer, then unscrew the nut SW7 with which the two green-yellow cables are connected and loosen it. The two brown cables on the other side can stay if you just put the cover on top.
    • Place the top cover on top, or remove it entirely.
  7. DeLonghi ECAM series grinder replace, Grinder: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ECAM series grinder replace, Grinder: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the machine so that the grinder faces you. The grinder stands in the machine without further attachment. You only have to follow the course of the two black connection cables and disconnect the plugs.
    • Turn the machine so that the left side is facing you.
    • The black cable is part of the cable bundle. Cut the cable tie first. Replace it with a new one when reassembling.
    • Loosen the flat plug at the end of the black cable. You have to push in a small catch on the connector.
    • Remove the black cable.
  8. DeLonghi ECAM series grinder replace: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ECAM series grinder replace: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the machine so that the other side is facing you. The second black cable leads from the back to the control board.
    • Cut the cable tie on the cable bundle here as well. Replace it with a new one when reassembling.
    • Pull off the flat plug at the end of the cable. You have to push in a small catch on the connector.
    • Remove the second black cable.
  9. DeLonghi ECAM series grinder replace: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM series grinder replace: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DeLonghi ECAM series grinder replace: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the machine with the rear side facing you.
    • Lift the grinder up and out.
    • Remove the red silicone ring from the top of the grinder and transfer it to the spare part.
Follow this guide in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
286.849 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
Thanks , just needed to replace grinder in magnifica S ECAM 22.110.SB.
Different machine but very similar.
In all that you have shown above; it all helped thanks but also made me look
more at the individual parts and how its put together.
What I needed as the machine is 8 years old so I'll either be replacing a lot of parts or
buying a new machine.
Ian.J Berry - crwdns2934203:0crwdne2934203:0
Thank you very much. That was very helpful. At least you knew what you were talking about. Other YouTubers talking about cleaning or replacing the “The grinder” just explained how to carry out a normal clean of the brew group.
Dave Wood - crwdns2934203:0crwdne2934203:0
Dank voor de duidelijke handleiding! Het vervangen van de bonenmaler was hierdoor eenvoudig en snel gedaan. Goed voor het milieu om hiermee de levensduur te verlengen.
Gerben van Buuren - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 22
crwdns2936753:07crwdne2936753:0 162
crwdns2936753:030crwdne2936753:0 673
crwdns2942667:0crwdne2942667:0 10,127
