DeLonghi ECAM Series power board replacement
  1. DeLonghi ECAM Series power board replacement, DeLonghi ECAM back panel removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power cord!
    • Remove all attachments such as water tank, pulp drawer, brew group.
    • Turn the machine with the back facing you.
    • Remove five Torx T20 security screws.
    • A small hurdle: These screws have a pin in the middle, so the screwdriver must have a hole.
    Screwdriver must have a hole? What does that mean? Is it a standard Tx20 bit?
    Kevin - crwdns2934203:0crwdne2934203:0
    No, it is a TR20 Security Bit, which really has a hole (if you look to the star shape) . See TR10 Torx Security Screwdriver
    VauWeh -
    Bits from iFixit are equipped with it.
    VauWeh -
  2. DeLonghi ECAM Series power board replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ECAM Series power board replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift out the back.
    • The following components are immediately visible:
    • grinder
    • pump
    • flowmeter
    Sehr gute Anleitung. Die Security Schrauben der Rückwand können auch durch normale Kreuzschlitzschrauben ersetzt werden. Natürlich mit gleichen Abmessungen. Es erleichtert bei späteren Reparatur Arbeiten die Werkzeuge Auswahl , da überall Kreuzschlitzschrauben verbaut sind.
    Willi Greubel - crwdns2934203:0crwdne2934203:0
  3. DeLonghi ECAM Series power board replacement, Replace power board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Also slide the cover - if not already done - on the water tank side backwards and remove it.
  4. DeLonghi ECAM Series power board replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The power board is located under the cover. It is fixed with four screws in the corners and connected with a lot of cables.
    • Move the cables a bit to the side and unscrew the four Phillips screws in the corners.
  5. DeLonghi ECAM Series power board replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DeLonghi ECAM Series power board replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The cables have many different connectors and can almost not be confused. Make a special note of where the flat connectors are connected.
    • The flat connectors can be disconnected more easily if you lift the cover in the corner of the device to the side.
    • Lift the board out a few centimeters.
    • Carefully loosen all connections. Some are secured with latches that you have to push away first.
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
265,743 crwdns2915208:0crwdne2915208:0
crwdns2935297:0297crwdne2935297:0
Just wanted to say thanks for posting this; successfully fixed my machine today. The cables are an absolute pita to get off the old board and I did need tweezers and needle point pliers.
Dave Morris - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 1,768
