De'Longhi EC155 Water Valve Replacement
  1. De'Longhi EC155 Water Valve Replacement, Water Reservoir: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 De'Longhi EC155 Water Valve Replacement, Water Reservoir: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip open the top panel to reveal water reservoir.
    • Grab the water reservoir by the handle and lift out.
  2. De'Longhi EC155 Water Valve Replacement, Bottom Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 De'Longhi EC155 Water Valve Replacement, Bottom Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device on its head.
    • Using the Phillips #2 screwdriver, unscrew the four 12 mm screws found at each corner of the bottom panel.
    • Lift the panel off or flip the device over and let the panel drop out.
  3. De'Longhi EC155 Water Valve Replacement, Top Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before flipping the device, removed the black container and grill.
    • Flip the device on its head, front end facing you.
    • Using the Phillips #2 unscrew the two 52 mm screws found underneath the top portion of the device.
  4. De'Longhi EC155 Water Valve Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device back to its proper orientation.
    • Using the Phillips #2 screwdriver remove the two 52 mm screws found on the lip next to the reservoir.
  5. De'Longhi EC155 Water Valve Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 De'Longhi EC155 Water Valve Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the two plastic opening tools beneath the top knob.
    • Use the two plastic opening tools as leverage to lift the top knob off.
  6. De'Longhi EC155 Water Valve Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the lid firmly with both hands.
    • Pull mightily with both hands away from the device.
    • If you hear a slight snapping sound, it is supposed to do that.
  7. De'Longhi EC155 Water Valve Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 De'Longhi EC155 Water Valve Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to push in the slot on the back panel while lifting.
    • Similarly, reach into where the reservoir used to be and insert a plastic spudger underneath the inside panel.
    • We recommend to not use your fingers for this step because there is a chance they will be pinched.
  8. De'Longhi EC155 Water Valve Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 De'Longhi EC155 Water Valve Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You are now ready to lift the top off.
    • Place one hand near the back, the other at the front, and lift.
    • You may want to lift the front and back individually by pulling one a little off the part before the other. Afterwards, lifting the top off entirely will be easier.
  9. De'Longhi EC155 Water Valve Replacement, Water Valve: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 De'Longhi EC155 Water Valve Replacement, Water Valve: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device and remove one end of the tube from the water reservoir hole.
  10. De'Longhi EC155 Water Valve Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 De'Longhi EC155 Water Valve Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the tube through the chamber with the water pump so it comes out of the top end.
    • Twist the valve counterclockwise while pulling gently.
David Griffith
crwdns2935283:010/01/15crwdne2935283:0
1,492 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-2, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 4-2, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S4G2
crwdns2935297:036crwdne2935297:0
crwdns2947412:05crwdne2947412:0
I done this earlier today without the guide after it started to leak after descaling the machine , so i fixed it by taking valve apart an putting back together it worked once before leaking again , im just concerned it will just go again if i replace the safety valve , im wondering if scale has moved an is blocking and causing valve to leak? any ideas?
Russell L - crwdns2934203:0crwdne2934203:0
Great description! Is the water valve ever used to control brew pressure?
Thatcher Drake - crwdns2934203:0crwdne2934203:0
Great guide!, carefull the water valve has inside, two small orings, don´t loss it. Muy buena guia, hice todo lo indicado y funciono perfectamente, mi máquina comenzo a gotear agua por dentro y gracias a este manual pude encontrar la falla, que es la válvula, tengo con la maquina mas de 7 años y hasta ahora fallo, la válvula por ser de plastico no se puede reparar, pero se consiguen las partes en ereplacementparts.com. Solo un comentario la valvula tiene 2 orings pequeños, así que tengan cuidado cuando la saquen no se les pierdan.
Nelson Troyano - crwdns2934203:0crwdne2934203:0
I update my comment, the spare part for the valve has arrived (ereplacementparts.com), I replaced it and everything is perfect, I can drink my espresso again.
Actualizo mi comentario, ya me llego el repuesto de la válvula (ereplacementparts.com), lo reemplace y todo perfecto, de nuevo puedo tomar mi expresso.
Gracias Nelson por el buen consejo!
Omar -
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 6,324
