This guide requires you to fully take apart the device. Be careful not to misplace any parts once you have removed them. This guide would be used if your coffee maker has no water flow.
Flip open the top panel to reveal water reservoir.
Grab the water reservoir by the handle and lift out.
Flip the device on its head.
Using the Phillips #2 screwdriver, unscrew the four 12 mm screws found at each corner of the bottom panel.
Lift the panel off or flip the device over and let the panel drop out.
Flip the device on its head, front end facing you.
Using the Phillips #2 unscrew the two 52 mm screws found underneath the top portion of the device.
Flip the device back to its proper orientation.
Using the Phillips #2 screwdriver remove the two 52 mm screws found on the lip next to the reservoir.
Insert the two plastic opening tools beneath the top knob.
Use the two plastic opening tools as leverage to lift the top knob off.
Grasp the lid firmly with both hands.
Pull mightily with both hands away from the device.
Use a plastic opening tool to push in the slot on the back panel while lifting.
Similarly, reach into where the reservoir used to be and insert a plastic spudger underneath the inside panel.
You are now ready to lift the top off.
Place one hand near the back, the other at the front, and lift.
Flip the device and remove one end of the tube from the water reservoir hole.
Pull the tube through the chamber with the water pump so it comes out of the top end.
Twist the valve counterclockwise while pulling gently.
Twist the frother clockwise while pulling gently.
Remove the four 16mm screws with a T20 Screw head.
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Remove each clip from the valve and core using the precision angled tweezers.
Pull out each LED with one quick tug.
Similarly, remove each set of wires from the setting tuner with one quick tug.
Flip the device and remove one end of the tube from the reservoir hole.
Completely remove the other tube from both the reservoir hole and filter to the water pump.
Twist the valve counter-clockwise while pulling gently.
Tilt the core towards the front while lifting from the back.
Remove both sets of wires from the black box.
Remove the filter attached to the bottom of the pump.
Pull off the black foam from the bottom.
Pull off the black foam from the top.
I was trying to remove the valve. I am not sure what axis to turn it on. Also how do I know if the valve is bad or the pump, or both?
Just get both parts. I think the valve is only a few dollars. The only moving part is the pump and that is by far the most likely problem.
shadowym -
Are you still taking feedback?
Die Schrauben auf der Bodenplatte sind nicht wie angegeben Kreuzschrauben sondern Safety Tamper Proof Star 6 Point.
