Daughterboard Disconnection
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Daughterboard Disconnection, Reposition the head strap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection, Reposition the head strap: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the head strap forward as far as it will go.
  2. Daughterboard Disconnection, Unplug the All-In-One Cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection, Unplug the All-In-One Cable: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the All-In-One Cable from your headset.
  3. Daughterboard Disconnection, Remove the All-In-One Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the All-In-One Cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the All-In-One Cable: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. Daughterboard Disconnection, Remove the top strap: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection, Remove the top strap: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the top strap from itself where the Velcro secures it.
  5. Daughterboard Disconnection: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. Daughterboard Disconnection: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. Daughterboard Disconnection, Remove the front side foam pads: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the front side foam pads: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the front side foam pads: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off both front side foam pads to uncover the speaker wires.
  8. Daughterboard Disconnection, Remove the two rubber spacers: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the two rubber spacers: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the two rubber spacers: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. Daughterboard Disconnection, Disconnect the speaker wires: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Disconnect the speaker wires: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Disconnect the speaker wires: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. Daughterboard Disconnection, Remove the head strap: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection, Remove the head strap: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. Daughterboard Disconnection: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. Daughterboard Disconnection: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. Daughterboard Disconnection, Remove the outer shell: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the outer shell: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the outer shell: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. Daughterboard Disconnection: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. Daughterboard Disconnection: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the seam between the two halves of the outer shell.
    • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
  16. Daughterboard Disconnection: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding the opening pick through each seam until all clips have been dislodged.
  17. Daughterboard Disconnection: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully slide each half of the outer shell off of the sensor array.
    • Be careful not to snag any of the ribbon cables underneath.
  18. Daughterboard Disconnection, Remove the face rest cushion: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the face rest cushion: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the face rest cushion: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to gently peel the face rest cushion off of the headset.
  19. Daughterboard Disconnection, Disconnect the microphone: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection, Disconnect the microphone: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger, or a clean fingernail, to flip up the locking tab on the microphone ZIF connector on the daughterboard.
  20. Daughterboard Disconnection: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to pull the microphone cable straight out of its socket.
  21. Daughterboard Disconnection, Disconnect the sensor array: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection, Disconnect the sensor array: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to peel the conductive fabric off the sensor array ZIF connector on the motherboard.
  22. Daughterboard Disconnection: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your spudger, or a clean fingernail, to flip up the locking tab on the sensor array ZIF connector.
  23. Daughterboard Disconnection: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to grip the left and right sides of the sensor array cable and pull it straight out of its socket.
  24. Daughterboard Disconnection, Remove the sensor array screws: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection, Remove the sensor array screws: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the four 3.0 mm‑long screws securing the top of the sensor array.
  25. Daughterboard Disconnection: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T6 Torx screwdriver to remove the four 3.8 mm‑long screws securing the front of the sensor array.
  26. Daughterboard Disconnection, Remove the sensor array: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection, Remove the sensor array: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the sensor array straight off the lens assembly and remove it, making sure you thread the cable through its slot.
    • During reassembly, make sure the sensor assembly cable is threaded through its slot before continuing.
  27. Daughterboard Disconnection, Remove the thermal pad: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the thermal pad: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Remove the thermal pad: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to peel up the thermal pad covering the daughterboard.
    • The thermal pad will likely remove the Kapton tape from the ZIF connectors on the daughterboard. Replace the Kapton tape if necessary.
    • Set aside the thermal pad. You'll reuse it during reassembly.
  28. Daughterboard Disconnection, Disconnect the lens assembly: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Disconnect the lens assembly: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Daughterboard Disconnection, Disconnect the lens assembly: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger under a corner of the lens assembly press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging nearby surface-mounted components.
    • Twist the spudger to lift the press connector up and disconnect it.
    • Repeat the same process to disconnect the other lens assembly press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  29. Daughterboard Disconnection, Disconnect the IPD sensor: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection, Disconnect the IPD sensor: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to lift up the locking tab on the IPD sensor ZIF connector.
  30. Daughterboard Disconnection: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to pull the IPD sensor cable straight out of its socket.
  31. Daughterboard Disconnection, Disconnect the proximity sensor: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection, Disconnect the proximity sensor: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to lift up the locking tab on the proximity sensor ZIF connector.
  32. Daughterboard Disconnection: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daughterboard Disconnection: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to pull the proximity sensor cable straight out of its socket.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
175,150 crwdns2915208:0crwdne2915208:0
crwdns2935297:0798crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,142crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 39
