Datsun 280z Fuel Line Replacement
  1. Datsun 280z Fuel Line Replacement, Fuel Injector Lines: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Datsun 280z Fuel Line Replacement, Fuel Injector Lines: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release the hood latch by pulling the knob within the cab towards you.
    • Reach to the middle of the hood and pull the lever upward to release the hook.
    • Extend the hood upward to view the engine.
  2. Datsun 280z Fuel Line Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Datsun 280z Fuel Line Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spark plug caps from the spark plugs by pulling straight towards you.
  3. Datsun 280z Fuel Line Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Datsun 280z Fuel Line Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Label each spark plug cap with masking tape corresponding to the piston it belongs to.
    • Set the spark plug wires aside to open up your work area.
  4. Datsun 280z Fuel Line Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Datsun 280z Fuel Line Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the breather hose above the fuel rail to open up room for you to work.
    • The clamp on this hose is missing parts. If you have an intact clamp, you will need to loosen it with a Phillips screwdriver.
  5. Datsun 280z Fuel Line Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Datsun 280z Fuel Line Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Datsun 280z Fuel Line Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the 12mm socket and ratchet, remove the four bolts anchoring the fuel rail. Two bolts will be near the injectors, one on the front of the engine, and the last on the other side of the engine.
  6. Datsun 280z Fuel Line Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bracket that holds the injector plug-in wires to the fuel rail.
  7. Datsun 280z Fuel Line Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Datsun 280z Fuel Line Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the clamps that attach the fuel line to the fuel rail using the Phillips screwdriver.
    • Slide the clamps down toward the fuel injector to allow the fuel rail to slide out.
  8. Datsun 280z Fuel Line Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Spray the silicone where the line is still attached to the fuel rail to lubricate the fuel line.
  9. Datsun 280z Fuel Line Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the pick and loosen the hose from the fuel rail. Slide the pick between the fuel line and rail.
    • In a circular motion, move the pick around the inside of the hose.
  10. Datsun 280z Fuel Line Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the fuel rail out of the fuel injector lines until it is completely out.
    • You will have to maneuver the fuel rail to remove it from the fuel lines, but do not bend the fuel rail itself. It is metal piping that transports fuel to the engine. If the fuel rail is bent, the engine will not receive fuel to run properly.
  11. Datsun 280z Fuel Line Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Datsun 280z Fuel Line Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the clamps off the fuel lines.
    • Set them aside on a flat surface so you do not lose them.
    • Use the box cutter to cut the fuel line from the injector ring to the open end of the fuel line.
    • The box cutter is sharp, so be careful to not gouge the injector itself. Fuel can leak out around the fuel line if you cut the injector.
  12. Datsun 280z Fuel Line Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the pliers, grip the fuel line and twist it off of the injector.
    • Be sure all of the hose is removed and the ring stays on the injector.
  13. Datsun 280z Fuel Line Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Datsun 280z Fuel Line Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Datsun 280z Fuel Line Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the hose cutters, cut off a piece of the new fuel injector hose that is the same size as the old fuel lines.
Damon Byrd
crwdns2935283:007/03/18crwdne2935283:0
247 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S2-G3, Crane Summer 2018 crwdns2935289:0Eastern Washington University, Team S2-G3, Crane Summer 2018crwdne2935289:0
EWU-CRANE-SU18S2G3
Good instructions including visual. Question, I have a 1980 280 ZX on which I had to have the fuel tank rebuilt. When replacing it I removed all the old hoses, fuel pressure regulator, and relief valve. I should have made better notes or taken pictures. I am uncertain where the relief valve goes as I'm reassembling. I am purchasing a new adjustable fuel pressure regulator valve which will be relocated in the engine compartment. Any thoughts would be appreciated. Thank you.
Gary
Gary - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,520
