Designed as a low cost tablet for students in India, Datawind's Ubislate 7CI sells for about $35, to students in India, with the price subsidized by the government. The device is 7.2 by 4.8 by .4 inches (HWD) and weighs 11.2 ounces.
Be sure to repair your device on a clean surface so you are less likely to lose small parts.
Run your prying tool along the front edge of the device to pop off the front cover.
Once the halves are separated, your device should look like this.
(HINT: be careful of the device's small wiring when separating the two halves)
Use your prying tool to pop the speaker out from its housing.
Use a soldering iron to remove the speaker from its contact points.
Solder your new speaker to the same contact points as before.
Apply a small amount of adhesive to the new speaker, and place it into the housing on the back panel.
Put the two halves back together.
Push down on the edges until you hear them click into place.
