Daewoo DWC LDC1412S Water pump replacement Replacement
  1. Daewoo DWC LDC1412S Water pump replacement Replacement, Water pump replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the washing machine on it s back
  2. Daewoo DWC LDC1412S Water pump replacement Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daewoo DWC LDC1412S Water pump replacement Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 2 screw that keep the pump in place
    • You can now gently tear down the pump
  3. Daewoo DWC LDC1412S Water pump replacement Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Compare your actual pump with the spare you found BEFORE dismounting pipes !
    • Seems ok ? Let s go forward !
  4. Daewoo DWC LDC1412S Water pump replacement Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Daewoo DWC LDC1412S Water pump replacement Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Dismount pipes by pressing steel rings and moving then out of range of the pump
    • Do this for all pipes connected on the pump
  5. Daewoo DWC LDC1412S Water pump replacement Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pipes are now disconnected. Let's go for electrical connections
  6. Daewoo DWC LDC1412S Water pump replacement Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect both electro pump. Check were is white wire and black wire on each !!
  7. Daewoo DWC LDC1412S Water pump replacement Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move last evacuation pipe on the new part
    • ...you can know mount the new part and try your new pump !!
hellotheworld
crwdns2935283:012/06/14crwdne2935283:0
245 crwdns2915208:0crwdne2915208:0
Thanks, this saved me heaps of money!!!
Brendan Innes - crwdns2934203:0crwdne2934203:0
اگر برق ورودی به پمپ تخلیه هر دو مثبت باشد یا فاز باشد مشکل از کجاست
mehrad parva - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 87
crwdns2942667:0crwdne2942667:0 4,915
