Daewoo DWC LDC1412S Water pump replacement Replacement
Turn the washing machine on it s back
Unscrew the 2 screw that keep the pump in place
You can now gently tear down the pump
Compare your actual pump with the spare you found BEFORE dismounting pipes !
Seems ok ? Let s go forward !
Dismount pipes by pressing steel rings and moving then out of range of the pump
Do this for all pipes connected on the pump
Pipes are now disconnected. Let's go for electrical connections
Disconnect both electro pump. Check were is white wire and black wire on each !!
Move last evacuation pipe on the new part
...you can know mount the new part and try your new pump !!
Thanks, this saved me heaps of money!!!
اگر برق ورودی به پمپ تخلیه هر دو مثبت باشد یا فاز باشد مشکل از کجاست
I can't find this pump to purchase in the USA?
