DWFP55130 Regulator spring Replacement
Imran Latif
crwdns2944107:0crwdnd2944107:0Imran Latifcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Nhl 5, 2023crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
Repair for a faulty regulator on a Dewalt DWFP55130 air compressor.
Warning: Unplug power and remove all air from tank before attempting.
crwdns2944105:0crwdne2944105:0
  1. DWFP55130 Regulator spring Replacement, Remove regulator knob: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the black plastic regulator knob. While unscrewing, it will reach a stop and will keep like cannot unscrew further. Just break through the stop and unscrew to completely remove
  2. DWFP55130 Regulator spring Replacement, Remove plunger actuator: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use needle nose pliers to remove the plunger.
  3. DWFP55130 Regulator spring Replacement, Use Philips #3 (large) screw driver: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Very gently unscrew the valve with a Philips #3 screwdriver. Take care not to destroy the plastic part
  4. DWFP55130 Regulator spring Replacement, Remove plastic valve: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use needle nose pliers to pull plastic valve assembly out
  5. DWFP55130 Regulator spring Replacement, Replace broken screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace screw if broken. Photo is not of the original spring. The original spring had corroded and broken into 50 pieces. The spring doesn’t have to be a perfect fit, just has to hold the part in place. The original spring was approx 6mm wide, 20mm tall and 0.5mm thickness wire.
  6. DWFP55130 Regulator spring Replacement, Reassemble: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carry out steps in reverse to reassemble compressor and you’re done
Imran Latif
crwdns2935283:002/08/23crwdne2935283:0
158 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
do you know the replacement part numbers just in case?
myke - crwdns2934203:0crwdne2934203:0
The replacement parts are not listed in the manual and not available for sale. Hence this workaround.
Imran Latif - crwdns2934203:0crwdne2934203:0
what type of spring did you replace it with?
Gaeilge 6 - crwdns2934203:0crwdne2934203:0
Random screw I found from a 3D printer part. Size and shape were both different than the original spring. As long as the dimension are similar to 6mm wide and 20mm tall, it would work. The spring I used was not 6mm by 2omm but close enough that it worked.
Replaced and still leaks. Tried replacing o ring and still leaks.
Rollin Blanton - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 948
