Repair for a faulty regulator on a Dewalt DWFP55130 air compressor.
Warning: Unplug power and remove all air from tank before attempting.
Unscrew and remove the black plastic regulator knob. While unscrewing, it will reach a stop and will keep like cannot unscrew further. Just break through the stop and unscrew to completely remove
Use needle nose pliers to remove the plunger.
Very gently unscrew the valve with a Philips #3 screwdriver. Take care not to destroy the plastic part
Use needle nose pliers to pull plastic valve assembly out
Replace screw if broken. Photo is not of the original spring. The original spring had corroded and broken into 50 pieces. The spring doesn’t have to be a perfect fit, just has to hold the part in place. The original spring was approx 6mm wide, 20mm tall and 0.5mm thickness wire.
Carry out steps in reverse to reassemble compressor and you’re done
crwdns2947412:05crwdne2947412:0
do you know the replacement part numbers just in case?
The replacement parts are not listed in the manual and not available for sale. Hence this workaround.
what type of spring did you replace it with?
Random screw I found from a 3D printer part. Size and shape were both different than the original spring. As long as the dimension are similar to 6mm wide and 20mm tall, it would work. The spring I used was not 6mm by 2omm but close enough that it worked.
Replaced and still leaks. Tried replacing o ring and still leaks.
