DROCON Ninja Camera Replacement
  1. DROCON Ninja Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Camera Replacement, Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement, Casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement, Casing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DROCON Ninja Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
  5. DROCON Ninja Camera Replacement, Camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement, Camera: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement, Camera: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 5mm screws connecting the front two motor arms to the drone's body.
    • Use your fingers to gently pull the white plastic discs out of the motor arms.
  6. DROCON Ninja Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DROCON Ninja Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the motor arm and pull up and away from the drone's body.
    • Repeat this step for the other front motor arm.
  7. DROCON Ninja Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the two 3mm screws on the control board.
  8. DROCON Ninja Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DROCON Ninja Camera Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the opening tool flip up the black plastic clamp that holds the camera wire to the circuit board.
    • Gently pull the camera out from the control board.
Destinee Easterly
crwdns2935283:001/26/20crwdne2935283:0
274 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S3-G5, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S3-G5, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S3G5
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 234
