Remove back case of tablet by taking spudger tool to lift the back plate.
With caution, unplug speakers from back case of tablet.
Remove battery
Grab and apply light pressure to battery to release it from the back
Place off to the side carefully. Be sure not to disconnect cables from motherboard
Locate where the cameras are attached to motherboard
Now release and remove them from motherboard
Take camera out and place off to side
Remove motherboard
To do this you will have to unscrew a total of 5 .25in phillips head screws
Remove back metal piece.
Use plastic pry tool and go around the edges lightly and pop it off.
Using a plastic opening tool, remove the back screen pieces from the back.
Using the plastic pry tool remove metal frame.
Take the iFixit iOpener and place it on the glue
This will release the glass from the plastic frame
Carefully remove glass. If glass is already broken use gloves to remove glass.
