DKnight MagicBox II Motherboard Replacement
crwdns2869540:0crwdne2869540:0: 15 тыс.
2
24
118
14 712
crwdns2955950:0crwdne2955950:0: 21
crwdns2960008:021crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 10
crwdns2959974:010crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
In this guide we will show you a step-by-step replacement guide for the Motherboard. You want to be careful when unplugging the speakers and battery from the board itself in order to not damage any of the wires.
The motherboard contains the following components:
Power Switch
Bluetooth sensor
Auxiliary port
Charging Port
    1. DKnight MagicBox II Motherboard  Replacement, Front Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DKnight MagicBox II Motherboard  Replacement, Front Panel Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
    2. DKnight MagicBox II Motherboard  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DKnight MagicBox II Motherboard  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DKnight MagicBox II Motherboard  Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • There are four prongs on the grill in the corners, closest to the power button switch. Use the plastic opening tool to release all four prongs from the panel, and then slide the plastic opening tool along the edge of the grill to allow it to easily slide off.
    3. DKnight MagicBox II Motherboard  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DKnight MagicBox II Motherboard  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • On the back panel (Opposite to the side containing the two speakers), Use the Philips head PH1 to remove all 7 screws (Screws: Head PH1 , Length 7cm).
    4. DKnight MagicBox II Motherboard  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DKnight MagicBox II Motherboard  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull apart the two faces to separate the back panel from the front face plate.
    1. DKnight MagicBox II Motherboard  Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DKnight MagicBox II Motherboard  Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the single screw holding the motherboard to the front panel (Screw : Head PH1, Size .5 cm)
    2. DKnight MagicBox II Motherboard  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers gently pry the motherboard loose from the black insulant adhesive
    3. DKnight MagicBox II Motherboard  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the Button Panel plug (Largest of the Plugs, it can be traced back to the button panel easily)
    4. DKnight MagicBox II Motherboard  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the tweezers to push down on the safety prongs on the plastic switch. Then Disconnect the Power Wire plug by hand (Red medium),
    5. DKnight MagicBox II Motherboard  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the tweezers to push down on the two safety prongs on the plastic switch. Then Disconnect the two Speaker plug connections by hand (Two Smaller Plugs)
    6. DKnight MagicBox II Motherboard  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DKnight MagicBox II Motherboard  Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The Motherboard is now free from the speaker assembly
crwdns2935229:010crwdne2935229:0
Anthony
crwdns2935283:002/04/16crwdne2935283:0
704 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-1, Blackwell Winter 2016 crwdns2935289:0USF Tampa, Team 17-1, Blackwell Winter 2016crwdne2935289:0
USFT-BLACKWELL-W16S17G1
crwdns2935297:036crwdne2935297:0
crwdns2947412:021crwdne2947412:0
Where can I buy a replacement DKnight MagicBox II Motherboard ?
Francis Garvey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Charge Port is not working, do I need to replace the Motherboard or is there a fix for the charge port? Verified that the cable is good. It use to work if I wiggled and applied pressure to one side. Verified port is clean.
Michael Stills - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where do you get the replacement motherboard?!
Tracie Yang - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I did the steps and the power still won't turn on. The blue light will turn on for a blink then nothing
rachelharris0528 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
mine is doing same thing. DKnight said they wont do anything because i bought it off Ebay and not Amazon.
Peter Tavella - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 118
crwdns2959996:0crwdne2959996:0 14,712
