The battery can be considered the heart of the device. Without it, the devices will not work and will be useless.
So that your enjoyment does not get ruined by a dead battery, this guide provides instructions on how to replace the battery on the DJI Phantom 4 Advanced Remote Controller.
Remove the four screws with a Torx T8 screwdriver to access the back con board.
Remove three screws using a Phillips #00 screwdriver.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
With tweezers, gently remove the large con board tab.
Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
Peel off the rubber grips to access the screw holes.
Remove the back board and set it aside.
Pull apart the back plastic panel.
Once the back panel is off, you will have access to the motherboard.
Unplug the cord that is connected to the bottom of the main board.
After the cord is unplugged, remove the battery by lifting upon the plastic cover, which the battery is attached to.
Once the cover is off you can access the battery.
crwdns2935229:09crwdne2935229:0
Grrrrrreat Job!
Wo kann ich den Akku bestellen? Danke für die Hilfe!
does someone know where to buy the akku?
Ich habe ein Erzatz Akku eingesetzt mit den gleichen Strom Werten, beim aufladen stelle ich fest das der Akku nicht ladet..
Es blinkt bloß ( schnell) auf einer LED.
Wo kann die Ursache liegen.
